Wobbly seats
(In Topic #93873)
Wobbly seats
The seats in my '85 mk1 cab are very very loose an rock about side to side…..are they all like this or is there anything I can do to hold them in better?
I saw some seat runner clips on fleabay for about ?4. that seemed to suggest that they could fix the loose seats but will these do the trick?
Re: Wobbly seats
There are no guarantees in life but the probability is that yes. These can wear out and come off over time so I'd get a set and try it out.
Tian :wink:
If it wobbles with the movement at the back, it will be these. The other parts involved are metal, so unlikely to wear to that extent, in fact I could bet the plastic runners are missing.
If it wobbles at the front , there's another thing which sits here and makes it run smoothly, a wedge-like piece of plastic/rubber.
Chairman
I've replaced the two side runners and the front rubber mounting and it tightens the seat up nicely. mkae sure you get the correct ones. They are 'handed' left and right.
Nothing more off putting than a wobbly seat when you're cornering!!!
Dan
Dan
My clips from ebay turned up, 2 grey and 2 white clips, but they came with no instructions. Doh!
Stupid question, but do they just push into the seat runners?
Yep, they clip on.
Tian
pics below of the drivers seat clips if thats any help.
1988 1.8 carb Golf Clipper
Have you a Ebay site for them as I need some
Gary
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
Cheers, yeah the pictures are a big help!!
There are some on ebay here: http://cgi.ebay.co.uk/…ZWDVWQQrdZ1QQcmdZViewItem
stuff like this has to make me laugh a bit...rememebring when my bro managed to bust the passenger seat, all he did was adjust it lol
Thanks for the help!
Got this sorted this morning. I no longer fall into the passenger seat when taking right hand corners
Just thought you might like to know. GSF do these for about ?1 as opposed to ?4-5 off theaf bay
what they under on GSF........Im probably going round in circles like I have all night looking for the things
Think they're called a seat clip
Bugger….looked that up on gsf and havent had any luck finding them
I put these new clips on my car stopped all wobble but STILL it's still very hard to move both seats forward and back
1983 GTI-Black
Finny said
Bugger….looked that up on gsf and havent had any luck finding them![]()
Why not just give them a ring?
GWTaylor, I've got new ones and yes that are a snug fit, my advise, stop playing with the seat mate!
Tian
Go to vw water cooled - golf mk1 - interior
they're called seat runner clip inner and outer, part numbers 88530 and 88532.
Or you could just go into a gsf shop, they'll probably know the parts
Have you tried a little bit of grease on the clips and in the runways, where they slide ??
G60
I had a car that someone had jacked up on the floor panel bending the seat runner, that can cause the seats to not slide properly!
