wobbly accelerator pedal
(In Topic #89760)
Just noticed my accelerator pedal was wobbling about a bit
Had a look and the round bar that runs from the bottom of the pedal to a bracket on the bulkhead seem to be missing a circlip. the bar runs through a bracket and has a groove near the end which I assume must be for a circlip or something
Anyone know what size it is or where I can get one?
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
Not sure if you've got the same setup as my Cabrio's accelerator pedal.
This originally came with a foam bushing that held the round wire connector in the circular hole on the pull rod running through the bulkhead.
Only the foam bushing was a goner - so I replaced mine with a couple of rubber washers for a domestic tap, pushed onto the end of the round wier connector - cheap as chips
AliCabrio
AliCabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
Mine is the same on my 1983 tin top,
it has a red rubber 'bung' pushed in the mount on the car and then the spigot from the accelerator pushes in the middle.
I would try the vw dealer first and if they have stopped making them i reckon you might be able to make one out of a rubber bung from the top of a old style home brew bottle kit, if that makes any sense, as they look like the same kind of rubber and same colour.
