Window Rattle
(In Topic #132086)
Window Rattle
Looking for some advise as still new to the mk1!
When i have the front windows down it sounds like the glass is shaking around in the window frames/runners, when the glass is shut theres almost no noise at all. (also the passenger side doesnt go down as far as the drivers side?!?)
Looking from the outside between the glass and the scaper theres a gap but only 1-2mm.
Can you tighten the window mech's at all or do i need new scraper seals? Or something totally different!
runners lose, trim missing broken mech even
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
https://www.vwheritage.com/vw.cfm?act=vwclassicParts.search&classicSearchText=171837489A&country=GB&lang=EN
Last edit: by hayhur01
on yours I would check the condition of the felt slot down the front guide, and the fit of the rearmost guide bolted to the glass on the metal runner inside the door
also wiggle the rear guide, make sure its bolted tight. it has one nut at the top and some bolts in the very bottom of the door
plus give the glass a good wiggle and see if you can feel where the play is
