Wheel arch trims
(In Topic #89485)
Wheel arch trims
Whats the best wax or sealer to but betwwen wheel arch trim and arches to prevent rust?
Cars been painted had new rear arches/wings fitted. Will be making fresh holes to screw into.
Its now 4 years and there isn't one bit of rust on them.
If you do go down the self tapper route use stainless ones. You don't want standard steel ones which will rust and encourage the body to rust too
I would definitely recommened a few coats of waxoyl though prior to fitting your arches. I'd put it on 1 layer at a time and let them dry each time. Then when it comes to fitting your arch you wont just wipe it off when you offer them up. Another TOP TIP. Unless you have front mudflaps fitted you are likely to get lots of annoying little stones trapped between the lower leading edge of the rear arches and the body. I ran a small slither of black sealant down this join. Not noticeable once you've run a damp finger down it and wiped off any excess. It'll keep those stones out of there too.
DubPartz
Will aid rust proofing between the screw and panel.
therat1 said
glue them on with tiger seal?
dnt do this you will never get them off again
1983 1100 C
1983 1100 C
Now I'm really not sure!
I've just had my car back from the paint shop but the problem is that I have had the arches rolled. This means there are no arch lips to 'screw' the trims on to?!
I was goiong to bond them to the arches and I know that this is pretty permanent but I don't intend to take them off again anyway!?
What do you think? :dontknow:
G60Jonny
DubPartz
but......
If they're bonded and sealed then there's no chance of the water or dirt getting behind them therefore no chance of the arches rusting etc etc…or have I really missed the point?! ops:
