water water everywhere even after new roof (Clipper)
(In Topic #82496)
stuff about non-soft tops…so any advice/tips welcome
the hood was knacked anyway and had to be replaced,but water is still
pouring in.after this weekend at least 1" of water right through bottom
of the car - lucky i had not put the carpet back in after first noticed leak
and removed it -had to throw underlay away it was totally minging,must
have been wet for years.
this afternoon a guy at a local spares shop showed me the drain plugs under
bonnet they both totally blocked with muck,have cleaned them out.
i take note of the rear light clusters but am too thick to really understand-
can some kind soul explain in words of one syllable?
and any other ideas as to where this flipping leak is?going to and from
work is like being in a U-Boat with all that water slooshing about!!
please dont say "buy a henry" LMFAO
also - any tips of removing those glued to the floor sound-deadening panels?the water is even under them and they starting to crack..
spasiba…
top right of the door window, maybe the rubbers have gone and arnt sealing tight?? :dontknow:
i did my roof this year and im gettin leaks in thro the rear window too, you need to really chase the leak when its not rainin, with a bucket of water well thats what i did.
best of luck
rebuild in progress....
Give us some more clues so we can help.
Tian :wink:
cheers each
i'll let you know asap,have been putting tarp over it,need nice day
and trip to area outside hosepipe ban LMFAO - its still in force here.
i have funny feeling it was the drain-away pipes on the gulley under the bonnet.they were blocked solid..
Try this first.
Tian :wink:
'89 Golf Clipper Cab (WIP)
I found this out with my first mark one years back when it lived under a tree outside the house. one morning going to work had wet feet!
The current Mk1 cabrio suffered with a wet floor, especially on the Pass side. Took me a small while to find it. Water was dripping off from the radio antenna wire, that comes through the bulkhead. The rubber grommit was missing. As water was running down from the catch tray rubber drain holes, the antenna lead was transfering water into the car. loads of silicone filled the hole, where the grommit lived. Dry now!
hope it helps
Tian said
Probably just the foam seal that goes between the carrier and rubber.
Tian :wink:
any idea of the part numbers for the foam seals ..?
Loving any chrome or carbon bits...
GOODVIBRATIONS said
Tian :wink:
Sorry mate I haven't got a clue. Just nip along to the parts desk and explain, they'll find it on the computer for you. Don't let them charge you more than ?10.00. If it costs more than that it's the wrong part.
Tian :wink:
Cheers,
Ross
Ross said
155 871 431 is the part number. I think you get 3 strips per bag, enough to do one side of the hood… front, middle and back sections of the frame.
Cheers,
Ross
Now that's service.
Tian :wink:
?2.45 per strip, havent got any in the uk..
heres the diagram i got
item No 35A + 35B ??
spoke to a guy that fitted my roof "Soft Tops" he said that draft excluder can be used. :dontknow:
