waist line trim not sticking - any suggestions...?
(In Topic #154946)
Anyway they just wont grip, any ideas? I was going to resort to trim tape that you use to fix the badges to the car?
will hopefully post some pics of it finished over the weekend
thanks
Website Manager
What do you think about clips and trim tape? or maybe the thinner type trim like this: http://m.vwheritage.com/productDetails.cfm?iItemID=35813406
thanks
Chairman
DjEv tried my trims in the car park in the hotel before we went to Germany…. The result was that he did manage to flick one off and I had to ride round the continent with tape holding the trim on!!
On my return I got the mastic gun out and put some dabs under the trim to hold it. The clips were genuine and I suspect - as you do, that the fresh paint doesn't let them grip as well.
Chairman
Keep an eye on your "mates" at all times !!!
There are two types of clips, one is slightly bigger. The one I need is 155853585, however they are about a pound each from vw heritage!! Anyone know where I may get them cheaper? The ones on eBay are all the small size part starting with. 113 not a 155
Chairman
How did you find that our??!!
got the slightly larger ones from VW heritage. They are original VW parts and are a much better fit and hod the trip much more securely than the other slightly smaller types. You can tell the difference as the larger ones dont have the small red washer with them
Chairman
Strangely, just as DjEV drives past my house!!!
Website Manager
lost 1 of my waistline trims the other day, fortunately another member had a full set in very good condition available… (cheers rich hill)
my question is i have purchased new trim clip's from heritage (part no. 155853585) but they seem very loose in the hole in the wing..?
havent got to trying the trim as the clips seemed far to easy to pop out..?
have an idea where i might be going wrong but thought i would ask other members first….
adrian
The clips don't work for the trim below the door, you need bigger ones for this trim
took 2hrs to figure this out, then put old trim back on instead of the new one….
cheers for reply anyway..
adrian
