very wet passenger footwell
(In Topic #151945)
AFTER THE RAIN
RAIN HAS MADE MY PASSENGER FOOTWELL VERY WET PLEASE HELP LEAK FROM SOMEWHERE
Member 125 - 2005
Check bulkhead drain holes are clear and sny grommet s in the bulkhead including can leak through the sound deadening , also corner of the windscreen , door cards/ plastic sheet intact , sunroof drain holes . Rear light seals
Door drain holes at the bottom of the doors. Tin top or cabby?
If cabby porous roof skin, foam gaskets gone. J hooks adjusting etc
Mk1Jim could have its most likely leak. Very common if scuttle panel not cleaned out o water could be getting in via cabling run through bulkhead then check the doors.
My previous mk 1 had a bad hole aT the rEAr arch that soaked the whole footwell when driving in wet
also the seal around heater box can perish
