Vent heating
(In Topic #75832)
Vent heating
Is this as it should be?
Ian
'89 Clipper Auto and '92 GTI Cabby
Chairman
The levers control the system as follows…
As you look at the controls there are 3 levers top right, top left and bottom.
1. If you slide top left and right levers to the right, then air will be directed onto the windscreen.
2. Move left hand lever to left and air will go to windscreen and feet.
3. Move right hand lever to left and air will go to feet but not screen.
4. Move left hand lever to right while right hand lever is to left and the air flow will stop.
The side vents that are moveable will have lots of air passage if the levers are placed in possition 4 and will have reduced air flow if any of the other positions 1-3 are used.
Hope that helps.
Dan
Saves me some poking around/reading
Ian
