sunroof drain pipes
sunroof drain pipes
One last job.
the sunroof has drain pipes front and rear.
The rears are simple down the c pillar, back in front of the rear wheel arch and there is a little hole in the floor. :)
The fronts…… down the A pillar, but where do they go next. where do they exit, there is no hole to the scuttle panel on the off side. :banghead:  i assume the drain as near to the floor as possible,  :dontknow:
Anybody…..
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2018 VW Amarok V6
They should exit just above the upper front door hinges, just behind the front wing (only visible when front doors are open).
:D  Bingo. thank god for that  :D  :D  :D
Thank you Type 17
2018 VW Amarok V6
