Stopper
(In Topic #76186)
Stopper
Gurds
it reacted with the filler and primer I used and bubbled!
In the end I sanded it all off and threw the rest away! just needed to get an extra coat or 2 of primer on.. high build primer will 'fill' any pin holes left in the filler
let us know how you get on, I'll be respraying mine again next year but getting a pro to do the prep work.. can't handle the crisp packet look any longer!
Its only supposed to be used in the minutist of quantities after filler to fill up pin holes etc.
This is the front number plate surround from the sportline that was split with a fairly large chunk missing…
Here it is filled with UPOL SMC carbon fibre reinforced plastic filler stuff. Its good, you can see how I built it up to replace missing chunk. I'd initially superglued the split to hold it in the correct position.
So… here is the stopper on top. Its the yellow specs…
It filled the split nicely too.
Time to prime next!
i use it on the wheels as i do blow-ins, i cant apply too much paint so its gotta be as flat n smooth as possible
