Steamy windows!
(In Topic #75480)
Steamy windows!
Went to my car this morning…. I've got a leak….. damp in wheel well, rear foot wells and drivers footwell
My first issue with smuty and not a easy one to trace…..any ideas guys n gals? :dontknow:
Right I'm going to attack her tomorrow armed with a tube of silicon!
A good way to trace where its coming from is use some talcum powder the water will leave a mark where it has run from then you can hoover it up and fix the leak
The seals look pretty new apart from the top of the drivers door… I think I'll get some new ones of those.
Where can I buy new seals?
Any tips for drying carpets? :dontknow:
I knew it would test her moving to sunny Huddersfield!
I suspect my leak initiated from the Kamei spoiler fitted above the rear screen. It has clips which interfere with the tailgate glass rubber.
MK1 GTI Campaign
MK2 GTI 8v
Imitation Magic Tree - 'Black Ice' smell
Plenty of rust
Embarrasing fuel problem
Porous cooling system!
MK2 GTI 8v
Plenty of rust
MK1 GTI Campaign
MK2 GTI 8v
Plenty of rust
MK2 GTI 8v
Plenty of rust
Do you think they'll have a "Chudd you're such a funny man Ha ha ha" smiley?
Black MK1 GTI Campaign SOLD
Blue T5 GP 2010 Transporter (Van)
Orange M6L 2012 Brompton (Bike)
Neversummer 2012 Revolver (Snowboard)
Hey Kins thanks , just putting a bit of humour in to your thread .
Have you found the leak yet ? My Golf had a leak from the heater matrix and caused all the problems you have is it okay ? Look under the bonnet and make sure all chassis leg holes are sealed [especially at the rear ] , some only have painted gaffer tape over them . This is a direct route to under the carpet . Dont forget to dry the sound deadning felt under the carpet or you will promote unseen rusting
Cheers mate Chudd….
Any one got some in good nick? :dontknow:
Failing that I'm just gonna silicone it.
Ref the door/window seals you can buy form VW still - the hockey stick shaped ones that is.(Or go to scrappy and use the insie one from the other side as shouldn't be too worn.)
