Steamy windows!
(In Topic #75480)
Steamy windows!
No its not because I've been up to jiggery pokery!
Went to my car this morning…. I've got a leak….. damp in wheel well, rear foot wells and drivers footwell
My first issue with smuty and not a easy one to trace…..any ideas guys n gals? :dontknow:
rear light rubbers maby thats wat is was on are 16valve but it was a lot easyer to trace cause its gutted of furnishings and on the golf ive got now its under the dash running in through the window rubber all i did was stick sum silicon under the frnt window seal ,…… well thats my trouble …so maby it could be that or it could be sun roof
I have not got a sun roof! I'll check the light clusters…. did not even think of that one…..
Right I'm going to attack her tomorrow armed with a tube of silicon!
Loads of places to check: door seals, front window seal in the corners, rear lights, door membrains, look for wires going into the car without a grommet i.e ariel wire.
A good way to trace where its coming from is use some talcum powder the water will leave a mark where it has run from then you can hoover it up and fix the leak
Great tip with the talc Mr_GTI…I'll use that one.
The seals look pretty new apart from the top of the drivers door… I think I'll get some new ones of those.
Where can I buy new seals?
Any tips for drying carpets? :dontknow:
I knew it would test her moving to sunny Huddersfield!
There's always the obvious test - the 'hose' test. You could sit in the car and someone directs a hose at various places, etc. I have the same problems, the rear mat has a felt underside which seems to trap and never release the water. It took around 3 days to dry out, in the house with the central heating on. The car, had some water in it which was cleaned up but it never dried out on its own, despite my best efforts. So yesterday evening, I left a fan heater in it for a couple of hours, with the front window ajar, and its dried out nicely.
I suspect my leak initiated from the Kamei spoiler fitted above the rear screen. It has clips which interfere with the tailgate glass rubber.
Have a look at the thread about my MK2.Loads of suggestions on there! Just not in a position to try them all this weekend
MK1 GTI Campaign
MK2 GTI 8v
Imitation Magic Tree - 'Black Ice' smell
Plenty of rust
Embarrasing fuel problem
Porous cooling system!
MK2 GTI 8v
Plenty of rust
Kins,totally off topic but I found the 'ner ner ne ner ner' smiley you wanted
It even had hands at the side of it's head! On smiley central if you're interested :wink:
MK1 GTI Campaign
MK2 GTI 8v
Plenty of rust
MK2 GTI 8v
Plenty of rust
Cheers mate I'll check it out.
Do you think they'll have a "Chudd you're such a funny man Ha ha ha" smiley?
hovers that suck up water are cool 8) i like my vax
Black MK1 GTI Campaign SOLD
Blue T5 GP 2010 Transporter (Van)
Orange M6L 2012 Brompton (Bike)
Neversummer 2012 Revolver (Snowboard)
Mine does too - and its not as expensive as a Vax, in fact it only cost ?12 or so. Does anyone know how to fix hoovers? I sucked up a bunch of water with it, and now its stopped working.....
Hey Kins thanks , just putting a bit of humour in to your thread .
Have you found the leak yet ? My Golf had a leak from the heater matrix and caused all the problems you have is it okay ? Look under the bonnet and make sure all chassis leg holes are sealed [especially at the rear ] , some only have painted gaffer tape over them . This is a direct route to under the carpet . Dont forget to dry the sound deadning felt under the carpet or you will promote unseen rusting
Cheers mate Chudd….
Its still leaking a bit…. I think its the rubbers around the rear lights.
Any one got some in good nick? :dontknow:
Failing that I'm just gonna silicone it.
Dont forget to check you drain tubes at each side of the scuttle area!
Ref the door/window seals you can buy form VW still - the hockey stick shaped ones that is.(Or go to scrappy and use the insie one from the other side as shouldn't be too worn.)
