soft top mold?
(In Topic #131116)
soft top mold?
Hi guys,
My 1990 GTI cabriolet has quite a lot of green mold gathering on the surface. The material is the modern day material of mo-hair I believe…. basically the same as all the other soft tops out there.. its only a couple of years old and im a little worried its gonna cause me some leaks or something of the sort!
Does anyone know of any solution that can protect the soft top and git rid of the green mold growing on it? Its not attractive!!
Thanks in advance
Dan
Thanks in advance
Dan
mk1 golf gti 1800 8v (k-jet) cabriolet 1990 (typ 155)
You can get these softtop cleaning kits, one cleaner and the one proofer.
Ive used the turtle wax one and it works, also get a very very soft brush I got one for a rabbit from a pet store.
clean off as normal then use the cleaner, work in well with the brush should foam really well.
may take a couple/three goes to get most off over a couple of weekends.
finish off with the proofer/restorer.
If your is a couple of years old you need to find out why its going green so quick, parking under trees etc. I would try and find somewhere dif to park which I know is easier said than done.
1988 1.8 carb Golf Clipper
yeah strange i know… i park on a drive with no trees………………………………… arrrrrrrhhhhhhh (light bulb moment!!)
I park under trees at work!!!!
Right cheers, ill take your advice do you know where a can purchase these from? do you have a link or can i get this from the local halfords?
There are plenty of cleaner / protector kits out there.
Going from my experiance of mould on my old roof you will struggle to get it completly off.
www.archwayvaleting.co.uk
Cheers guys ive purchased some Renovo
Ive heard that if you spray vinegar on it this gets rid of it to…anyone else heard this?
