Seats
(In Topic #77180)
Seats
Does anyone know where I can get 1 of these from and has any1 managed to replace it without ripping the back off the seat?
thanks
Golf GTI Campaign - Helious Blue
thanks
Seats
Did the job on both my seats a few months ago……..
Cables are approx ?7-8 from VAG…
At the bottom of the back of the seat there are about 5 nasty hooks that go thru the material, they have to be straightend to let the material off the hooks and they bend under the seat (thats how the material is held on to the frame.
Next thing to do is to take the material out of the lever frame (when the material is loosened, the frame just hangs loose over the lever…dont worry it wont go anywhere….all you have to do then is to 'hitch' up the material as far as you can…u will see the way the cables goes (thru a couple of eyelets and then up to the lever…..it is a bit of a fiddle and there maybe a few 'words' spoken and grazed knukles…a torch is handy to look up inside the material……I did my two in an hour….good luck
TC
But obviously not
