seat lift mechanism
(In Topic #138885)
seat lift mechanism
thx
One that gies from the tilt lever to the lift mechanism and another cable that runs from one side to the other.
You can see which one is no good, just buy lifting the tilt lever and looking if you got movement of one of the levers.
The lower cable is easy as it just hooks in and out etc.
The one that goes to the tilt lever is a litre more tricky and may require the cover lifting up a bit.
Not sure if you can accsess it from the tilt lever cover surround and connect therevans then use a rid with the other end taped to it to feed it down, like a fish tape.
I bougt cables before from VW.
il then get one ordered from vw
thx m8
The short one runs across the back so just slip in and out.
Do a search on here it's bound to be covered, with pics too.
chortle
use your other seat for reference, tehy will be the same although diffrent handed lol.
Link below should give you some idea.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=8829
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=63093&highlight=tilt+release+cable
We need more of them to help out.
When I redo my roof later in the new year I may even do a Video… woop woop!!!!!!!
