sagging door mk1 golf ???
(In Topic #92820)
but that is not the problem, one of my doors are seriously sagging and i need to know how to repair this. i know of the use of a bolt but is there a PROPER way of rapiriing this and what causes this in the first place? cheers jk
lift from the open end, it bends the hinge slightly
83 Mars red GTI
01 V6 4Motion (daily driver)
09 Golf GTI MK6, candy white, superchipped!
83 Mars red GTI
I've never quite worked out the mechanics of why this works, but it does!
83 Mars red GTI
scottmk1 said
On my mk1 the gap between the door and front wing is tiny and the gap between the door and b-pillar is huge. How couls this be fixed?
Put a metal spacer or a couple of washers between the A pillar and the hinges and put the hinge bolts through them.
The same thing can be used to make slight adjustments to lft the door up a little.
Baz
scottmk1 said
but that would bring the door even closed to the wing seeing as the door hinges mate up to the forward facing surface of the apillar hinges.
Ah yes - that's what I get for thinking about the MK1 while working on a different car.
So would I be right in saying that putting a spacer between the hinges and the door might work then?
scottmk1 said
na, i need to move the door away from the A Pillar, not closer to it.
Damn it - I forgot that was welded.
Back to plan A. A little gentle persuasion involving a load of pressure and possibly a hammer.
How big is the gap at the b pillar?
Baz
