rust
(In Topic #73670)
rust
cheers in advance,
paul
To do a proper job you'd want to replace the rot with metal, but welding in new metal is prohibatively expensive unless you do it yourself. Cheapest and easiest option for a good/long term repair is to source a rot-free 2nd hand bootlid in your cars colour car, seen a few go on here recently for little money.
1983 1100 C
1983 1100 C
For ?40 though, He is probably not going to do the best repair…
My Build Thread
Just what I was going to ask about!
My lhasa green campaign is suffering a similar problem, whereby water has dripped from the upright rear wiper blade and settled aove the rubber window seal. Over the years the moisture has crept under the rubber, and under the black trim that goes around the whole rear window.
This has caused considerable 'bubbling' in this area - much to my displeasure, as the rest of the body is very good (only covered 50k and i'm its second owner). I had been considering a repair, as I would prefer the car to retain it's original bodywork. However having read the above i'm nolonger sure that this would be the best option.
A couple of questions:
Any ideas how much it should cost to get this repaired to a high standard (in the surrey area - if thats any help!)?
Has anyone got a good lhasa bootlid they'd flog me (badges and black trim condition not that important - i can get these - but colour and overall condition must be very good)?
Any help gratefully recieved!
Chris
'because everyone needs something in life they can rely on'
1983 1100 C
1983 1100 C
cheers for help,
paul
Works for front screen also.
When reinstalling use thin builders line as it is nylon and slides over the rubber well.
ill give it a blast sunday,
paul
if i have window out i may as well tackle it myself tbh
:clap:
The best way to do it…… yourself
1983 1100 C
1983 1100 C
a, bust windscreen myself
b, make an absolute shambles of the rubber
c, get the correct paint to match
d, stay sober
seriously though,
cheers for your help
Simon
'83 Mars Red GTI
Simon
'83 Mars Red GTI
Think washing up liquid contains salt/sodium in some form, which obviously is not what you want trapped under seals 8O
1983 1100 C
1983 1100 C
paul
