RUST!! Help
(In Topic #122683)
RUST!! Help
Hi, Ive found this rust next to the rear beam mounts and through to the arch. Im not a welder all though studying engineering in school. Im not quite up to welding this. I was just wondering whether you need to leave wholes there?? Breathing? :dontknow:
I think there must have been factory wholes there fr it to rust identically??
any help would be good as I need to get it welded up ASAP.
thanks
thanks
That area definitely needs welding/fixing! There are a couple of small slots where the outer sill joins to the inner, to serve as drain holes, there should be no others.
yes, definitely needs sorting. Ok, should I cut all of that area where it has broken away out and weld a plate in over it all??
