rotten arches!!
(In Topic #76128)
rotten arches!!
sorry
Arches are easily replaced but you need to get the welder out and get your self to you local Hadrian stockist for panels to replace the rot .
Search the site and you will find loads of info on the subject , loads of us have replaced rusty arches . Also search Amazon.co.uk and buy the restoration guide to the Mk1 golf there is plenty of info on arch replacement and loads of other usefull info .
You have to remember that your car is OLD and rust can be everywhere unseen until MOT time or when you start to poke about . So check the whole car using the buyers guide on this site just in case your rusty arches are just the tip of the iceberg and its rearly not worth doing .
What about some pics of the rust ? And the car ?
LOOK AT The Mk1 Golf Owners Club
AND The Mk1 Golf Owners Club
Don't give up - see it as a challenge as it will make the whole experience a lot more rewarding if you've had to overcome some tough problems on the way!
Heads up mate!
Jord
MK1 GTI Cabrio
Ford Mondeo (Daily drive)
Nissan 350z GT Coupe (the toy)
My old rusted arch ready to be cut out.
If your replacing the inner arch as well, cut the outer skin futher up, leaving about 10mm ish of the inner sticking out, so you can lap joint the new inner on the bottom of the old remaining inner arch, then i spot welded it on.
Then i clamped the outer on, to make sure it was siting right and tacked it on until i got it right.
Then i spotted the outer on, being careful not to let too much heat build up, i used a damp old sponge, to cool down the welds, and also when building the spots up, dont weld up all one side, spread the welds to different parts of the repair, so as not to make it bow out.
Then i ground the welds down, and fillered away, gaining sum blisters :roll:
Hope this helps, you just gotta get stuck in, then you can say you did it! :wink:
cheers lads
brought pattern outer arches from eurocar parts, not the best but did the job, can't complain when they were ?12 a side
Haynes do a good restoration manual for the gti, its good for all mk1s, that was my bible for about a year :wink:
Heres the ISBN 1 85960 448 x
Buy it you wont regert it, plus i just like reading it anyway (weirdo) :roll:
MK1 GTI Campaign
MK2 GTI 8v
Imitation Magic Tree - 'Black Ice' smell
Plenty of rust
Embarrasing fuel problem
Porous cooling system!
MK2 GTI 8v
Plenty of rust
Audi A4 1.9TDI - Gone
This is the Haynes to get.
1983 1100 C
1983 1100 C
I bought a GTi back in August but was very lucky as the bodywork and chassis was pretty solid. The sills & arches had all been replaced very professionally by the guy before me.
I knew the front & rear panel needed replacing which I had no problem with but the worst part was finding how bad the inner wings were. This hasn't deterred me though, I just cut out the bad stuff and welded the good stuff in.
Fabricating the pieces to fit to the inner wings was a bit daunting and I've got to admit I was a bit scared of it at first but I persevered. The feeling you get when you've sorted a problem is great and welding in new metal can't be beaten 8)
A welder is your new best friend and the Haynes Resto manual is very helpful (I got mine from http://www.play.com/play247.asp?pa=search&searchtype=bookall&searchstring=golf+restoration+manual&page=search as this was the cheapest by far)
Good luck
come on the mk1
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=6149
cheers j
