Removing glass
(In Topic #75865)
Removing glass
Can anyone offer any advice on removing the rear quater glass from my mk1. Is there a special tool required?. Also has anyone got any tip/advice on best way to remove the other glass?. I think i`m just going to cut the windscreen seal to avoid breaking the glass, cheers.
use a sharp stanly knife to cut the seal and apply even presure all the way around the window, you pussh from the inside and get a mate to catch it from the out side, well thats what ive done in the past, although i did smash a rear winscreen trying to pry it out with a screwdriver!!! whoops!
s#
NOOOOOOOOOOO!!! dont cut
all u need to do is from the corner inside, pull the rubber back as much as u can and apply pressure slowly to the glass from the edges and pushes it out, yeah and get a mate to catch it formthe otehr side!!!
or u culd just use ur feet if u brave but trust me just pushe it out evenly!
Birmingham
Life Member
I figured that i would be safer just buying a new seal rather than risking breaking the green tint glass. How about the rear quater glass? Is there a particular way of doing it? Cheers so far.
Same technique for the rear side glass as above. :wink:
I used 3 screwdrivers to lever the rubber out.. worked a treat on all the windows (except front which I cut
if you cut the rubber where can u get new ones, also is it the same technique for the tailgate glass, cheers
BACK SOON..............
nice avatar mk1_FSI
Crazyquiff here may have some.. or www.faroutparts.com or www.gpcvwaudi.co.uk
same for rear window but I found mine was in a lot tighter than the rest of the glass
cheers Phil, just managed to get the car to my house, eventually, so will begin work, just gettin all the info i need. any ideas on inner wing repairs?? cheers Dips
What you got to do to the inner wings? got any pics of what you need to do?
done the top edge and front on mine.. wasn't too difficult, take loads of measurements before cutting though to get the new metal in right
that sounds like the same area as mine needs attention, heres the link in new folks forum of some pics, any help will be greatly appreciated, cheers
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=4728
posted reply on your new folks thread as it's more relevent than removing glass
