panels hadrian/eurocarparts
(In Topic #75800)
just how bad are these and in soem cases liek cills get vws ones isnt a option?
I used hadrian panels and though they were quite good be prepared to do some trial fitting up and some bending of the folds behind the front wings. the scuttle panel repair pieces are rubbish though
Hi MadMan,
Very long time no speek, and I am on the VW turf not the ford one
Hadrian pannels are OK, used quite a few on my sierra and Crapi. you could search Ebay for genuine panels both inthe UK and europe but they are going to be ???
TT
TT
hi dude cheers but most are repair panels liek cills inner arches etc and are never available at any cost
Are you lookig for a factory finish?
I had to fabricate the inner/Mid sills on the Sierra ( still not finished after 5 years )
TT
TT
I fitted a Hadrian outer sill and arches (inner and outer last year.. fitted fine just needed to trim the bottom edge to make it straight.. the inner arch did need a little playing with to get it right
oh yeha factory finish going to be a show car unfortunatly its a 76 shell so needs some tlc
Fitted Hadrian inner/outer archs and fuel filler panel with few problems. You do need to spend a bit of time trimming and checking to get right, but you expect that when letting metal into a panel. I've a got a Hadrian O/S sill and N/S floor panel (not fitted) and don't look bad. Most of the bad reports about mk1 pattern panels seem to relate to complete panels such as front wings, front/rear panel and bonnet.
1983 1100 C
1983 1100 C
