My Series 1 has glass sunroof - what should it be?
(In Topic #141942)
"is it glass?"
I never knew the sunroof was aftermarket and what i now want to do is put it back to what it should be.
Was a sunroof ever an option on Series 1's?
What do you think i should do about it?
Any links to pictures of how it should be would be appreciated.
As much advice on restoring a Series 1 as possible please
When I returned to UK, I had a glass sunroof fitted between 80-82.
This was fitted by a Volkswagen garage in Totton, Southampton, while I waited, it was a VW promotion at the time.
I believe though, only metal sunroofs were available when you purchased the car from new and were fitted at the factory.
Hope this helps
I don't think a glass sunroof was ever a factory option. Glass sunroofs were dealer fit or other after market fit.
I would leave it as it is, unless you are already doing a full on resto and want to replace the roof and roof lining. A Paris Beetles style sunroof is also an option if it has leaks/rot.
My S1 has a dealer fit glass runroof, it's a period accessory and it doesn't leak so I'm keeping it.
if i can find the kit to change it back i will, but like you sid it does look period so no disaster otherwise.
cheers chaps
