My leaky cabrio .
(In Topic #114464)
My leaky cabrio .
I dont fancy a winter with a leaky roof
Thanks .
Check out the hood fitting guide, shows you all the relevant steps.
To check the windows mechanism is adjusted correctly wind the window up full and it should just get to the top of the seal on the qtr. When you take a look will be obvious.
Also when the door is closed on the 1st notch, sort of semi open if that makes sense. The window should be making contact on the vertical for about half its length. If not may need to adjust so window is slightly more inboard.
1988 1.8 carb Golf Clipper
bars.
djheap22 said
If the rubber is not split and the winder mechanism is adjusted correctly why not just get some new foam gaskets to go behind the seal. These where still available from VW a while back and you could put two behind just to pack it out a little.
funk-star is getting some of these in soon so you can buy 'em off him.
T
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150230609897
I know it works as my driver seal used to leak, and now it doesnt
I've had to completely strip the carpets out of my karmann and the underlay and soundproofing just fell to bits.
I tested the roof with a hosepipe and it seems it is leaking at the point where the roof folds. Can this be replaced?
Also, can the underlay\soundproofing be obtained from anywhere? or can anyone recommend an alternative?
Cheers,
Chris.
GTi Wrighty
but, I wanted an opinion on whether to have my paintwork tarted up before or after the roof?
one hand - paint goes on new roof
other hand roof scratches new paint!
Just going to try and find the hood fitting guide now to see if I really need to pay ?420 to have it done professionally…
you could have hood fitted then simply loosen the back edge where it goes into the lip before putting it in the paint shop?
Look like my next day off will spent with the wee golf trying to sort this issue .
