mk4 dash into mk1 cab
(In Topic #122310)
rikk said
ok guys i hold my hands up in shame. the mk1 dash is 50" and the mk4 dash is 53" max size i could push in is 51.5". so will def b going down another road. shame cause i found a whole mk4 dash for £30 at a localish breakers.
You would be better leaving the MK1 dash and putting the MK4 clocks ignition etc in the glove box so you can use the MK4 ECU . Try Edition38 or Club GTi for wiring information as this a common swop in the MK2 and MK3 Golfs but not as common in a MK1 . Most MK1 as you no use other aftermarket ECU's .
Cheers ………
dash conversion
Re: dash conversion
w55wes said
hi there, i have just completed a mk4 polo 6n dash board into a mk1 golf cab conversion and its very easy.. and looks the *CENSORED* in my opinion.. ive fitted the polo heater controls electric window switches, seat cordoba clocks and even the stalks fit 2.. if you require any info let me know and il try ta help
A 'How To'
Fit a Mk4 Polo dash in a MK1 with pictures , wiring diagrams etc would be a great addition to the How To data base
Can anyone giove ,me the dash board wiring diagram for a 1978 golkf mk1 petrol.
Thanks in advance,
Winston
DNWH
