Making the parcel shelf work!??!!
(In Topic #73001)
I'm very slowly restoring my '79 GTI. Most of it is original are still there it's got the early type parcel shelf rests - the ones without speakers and has, fitted to the back of my proper checked seats (!), a parcel shelf with all the metal studs intact and no damage or apparent sagging, like new you could say.
After all this it doesn't seem to all work as I would expect
Alex
Life Member
I think I'm missing something by what you say. I've got the plastic brackets which fit at either end of the metal retaining strip. Taking a look it appears to be the tethering strips - I can see the remains of these poking out from the shelf.
The tetherers look like they would have been about 20mm wide and maybe about 50mm long, is that right? I take it that these would connect to the plastic brackets, fitting over and being held in place by the retaining screw?
Do you know of any pictures I can look at?
Alex
Parcel shelf fit
It's really important to make certain the carpet is glued down to the back of the metal strip close to the rear seat. If the carpet is flapping around the shelf will be too long and no way will the hatch close without fouling it. Yes, the "black and white" short straps are really important as they locate the shelf forward enough for the hatch to close.
Cheers from Australia. Peter.
1978 Golf diesel (GLD)
1984 Nissan Patrol diesel
1982 Peugeot 505 turbo diesel
Alex
Chop up your dad's old Y-fronts!
