Leaky sunroof
(In Topic #134931)
Leaky sunroof
The only issue i'm having at the moment is that the sunroof is leaking…. i've had a look at it and the seals etc aren't looking too clever. Have tried Crazy Quiffs but they don't stock new seals and gubbins etc, so just wondered whether anyone know of any places that could sort it for me.
Any advice really would be muchly appreciated
Paul
then another possibility could be the rear catchment plate. Water can get in there if its rusted away, even if the drain tubes are clear. There is also a thin rubber seal between the plate & the underside of the sunroof. Worth checking, tho you'd need to remove the sunroof first. Can show up as a wet / dripping headliner if thats the problem… :roll:
If the tubes are clear then check that the bottom is still protruding out from the body of the car (the front ones can be seen sticking out when you open the door). If they've popped inside the body, the water can make its way into the footwell.
Twitter Manager
