I've got a pond in the back of my golf!!
(In Topic #75963)
God knows how this has happened, but after driving the golf Saturday, i reached down to get my lock from the rear footwell behind the drivers seat to be greated with a pool of water. It had gone through to the drivers footwell as well. Its as if someones poured a bucket of water in there! The waters definatly not coming from the roof, i don't think it's a door seal as theres no water on the sides of the carpet, and there are no holes underneath the car + the water isn't draining away either. Strange!! :dontknow:
I'm now mk1less, ahhhhhhh!
Gone but not forgotten;
'83 Schwarze black GTi
'83 Lhasa green GTi
'80 Indiana Red Met. GLS
'83 Lhasa green GTi
Place the screw driver (sharp end down :wink: ) at the lowest point in the floor and hit the other end with a hammer!
I would give this very technical proceedure the name "Creating additional, necessary drain holes"
I have one on each side of my car!
Of course, the real problem is locating your leak to prevent the water in the first place! Check your doors - Take the door panel off and check to see if the membrain is intact. Also check the lower window seals on the out side. If these are perished, you can swap the seals onto the opposite doors, so that the outside seals now sit inside and vice versa. The inner seals tend to have an easy life and last longer!
The water may also be coming from the rear. Check your boot seal and rear light clusters.
Could also be coming through the front scuttle panel/bulkhead somewhere, so check all your grommets etc.
Best way to find it is to take out the carpets and get someone to put a hose over the car while you lie upside down checking under the dash, in the boot etc!
Good luck!
AL.
My Build Thread
'83 Lhasa green GTi
'83 Lhasa green GTi
The footwells are joined front to back so it can be misleading. If you ared parked on a hill the water will end up in the lowest footwell regardless of were it leaked.
be careful to check befor you stick holes in the floorpan using neanderthALs idea, fuel lines are under the sills.
Just kidding Al, did you get that at school?
Peter.
1980 1600 GTI, daily driver.
sounds very similar to a problem i had, is your golf a sunroof model if so follow this link, hopefully it will help………ish.
www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&
t=5053
Jon
1983 mk1 gti 2.0l 2e powered
newman cam
ported, polished, big valve 1.8 head
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
tallpete said
neanderthAL
HAHA - Very good I like it!
It is a good point about the fuel lines though. They run under drivers side of the car - the brake lines also run under the passenger side, so just be careful if you do make a hole…
I actually used a much more sophisticated method to add "Additional, necessary drain holes" to my floor pan.
Drill and an 8mm drill bit - straight through the carpet and the floor pan!
In frustration, during my younger years
neanderth AL
My Build Thread
We used to get nice ponds, it was because the plastic liner benethe the heater air intake vents in the bonnet had been taken out.
And lately our screen has been leaking ( fixed now )
TT
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
'83 Lhasa green GTi
'83 Lhasa green GTi
Gonna have to fix it one day.
Probably not much of a hijack if penny needs to do it as well.
Peter.
ive never used them myself, but they might be worth a call?
http://www.gpcvwaudi.com
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
