Hood replacement - DIY or Professional
Should I attempt fitting a new hood myself? |
Absolutely - a monkey could do it! |
Hmm, maybe, as long as you know lots of swear words. |
No way Hos?! Leave it to the professionals. |
This poll is closed. You cannot vote unless it is reopened. | |
(In Topic #109253)
hoping this is the right forum - I think it most closely fits the bill.
I'm thinking of having the hood replaced on my Rivage prior to putting it back up for sale. I've had a trawl through a number of threads about places to get it done, but I'm after people's specific thought on:-
a) Whether to do it myself or put it out to a pro? (I'm generally pretty happy with '4 spanner difficulty' jobs). If DIY is a goer, where to source a mohair hood from.
b) If I just get it done, who would people recommend for a reasonably priced mohair hood, ideally somewhere in or near the Midlands.
TIA,
Cheers,
Nige
Cheers,
Nige
'92 Rivage
'71 VW Trekker
'70 1500 Ragtop Beetle
'65 Split Screen Devon Bus
'62 1200 Ragtop Beetle.
5 dubs, 1 solid roof :-)
Nige
'92 Rivage
'71 VW Trekker
I paid ?500 to have one professionally fitted to my Bordeaux Red Rivage by a Hood Manufacturer in Cwmbran South Wales, and it had a total of 3 roofs fitted (They made the first one with the Seam the wrong way round on the roof) and the second one did not fit at all well, and the third… I gave up and it still does not fit well across the Top of the windsreen and I now get wind noise, and they damaged the paint…
It's not *that* difficult, but depends how much rust etc you get.
Would recommend New wires too
–Roger
Arnold
Got a mohair roof/3 cables off ebay for ?150ish and followed the guide on the net.
Took about an hour to get old roof off, window out.
About another hour to treat rear window frame with hammerite.
Two hours to fit the new roof
Then I smashed the back window putting it back in
Still though, new one was ?30. If you add it all up, still under ?200 a massive saving and the larger part of a saturdays work.
I reused the window seal (it looked ok) and added a bit black sealant. It survived the winter fine and doesnt leak at all.
Window frame is work checking inside before you remove the roof to make sure it can be reused, peel it back and check rust. Mine was pretty bad but still perfectly useable after a coat of paint.
I think you've made up my mind to do it myself - WebbA - was your ebay purchase from a one off seller or a business?
Cheers,
Nige
'92 Rivage
'71 VW Trekker
Nige
'92 Rivage
'71 VW Trekker
Hopefully the Golf won't need as much welding
Early-1800 said
Is this the same Dipsy as in the Sky TV brown splitty camper bus?
Hopefully the Golf won't need as much welding![]()
That would be me :-) Fortunately the cab' is in much much better condition - the roof is far and away the worst bit.
BTW - I'm just looking for the hood replacement guide and I've completely drawn a blank :-( Could anyone point me in the right direction? Also, I saw on one thread a mention of 'prowlers DVD'. Assuming this isn't some sort of 'top shelf, special interest' DVD does anyone know any details? :wink:
Cheers,
Nige
'92 Rivage
'71 VW Trekker
Nige
'92 Rivage
'71 VW Trekker
1988 1.8 carb Golf Clipper
p.s loved the splitty mate
All I'd say is get a decent quality hood…mine was from BSA International (quality mate innit lol) and it went on perfectly…no wrinkles, no splits, and didn't need any faffing to get the edges all pointing in the right direction. I'm VERY impressed, but I've heard a lot of people say they've had a pig of a job getting the roof to fit tightly and spent hours adjusting, which now makes me wonder if they had cheaper hoods?
The bulk of the work for me was repairing and treating the rear window frame and treating little bits of rust around the tension cable lip.
I was fortunate enough to get the hood from a liquidation sale for ?80. This, plus new side cables and springs, new seal gaskets and paint cost me ?100. ?100 for a new roof! DIY wins. :mrgreen:
1989 MK1 VW Golf GTi Cabriolet, 'All White Edition' - currently having a new blue roof fitted. Yes it's not white but it requires less Cif to clean
