going for the new look
(In Topic #72495)
Thanks.
Shouldn't be too hard a job to fix the carpet back in yourself. I think the biggest issue is if you still have the underlay in the front footwells? This is quite thick and without it you'll probably think the carpet has shrunk a lot and wont get it to fit!
Life Member
Pull the carpets (easy does it, they do tear), beat them like crazy then next time you get your house carpets shampooed get him to run over the car's too. Use carpet spray adhesive from your local carpet superstore to stick them back down. Worked fine for me.
Rajan
G6EORGE has a posting lower down this "Restoration" forum (page 2) which refers to replacement moulded carpets……he refers you to Newton Commercial via the following link :
http://www.performancevwmag.com/forum/topic.asp?TOPIC_ID=26242
Check it out if you're looking to fit new carpets
I have had rubber mouldings for my Riley Elf from:
Classic Car Trim and Vehicle Trim by East Kent Trim Supplies
They tend to British cars but could maybe be "coerced" into providing replacement window/door seals although they stock lots of sections some of which may do the job
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
oh! and thanks for those links superworm i will check them out.
Gaz
