front and rear valances under bumpers?
(In Topic #75879)
I'm in the same scenario as you and have taken the decision to try everything myself. I'm grinding away any rust and using the glass fiber fillers for deep holes and the P38 filler for small ones. You might as well have a go yourself as the cost difference to get a prof to do it won't be that different if you've already tried. You never know - you may do ok! Just make sure you treat the body work that you grind to prevent any further rust. Halfords sell all the stuff to do the job yourself. Keep us posted on your progress. I've just got the wheel arch bumpers to remove and will be doing some grinding myself this weekend (weather permitting). I'll let you know next week how it's going!
Jord
MK1 GTI Cabrio
Ford Mondeo (Daily drive)
Nissan 350z GT Coupe (the toy)
will be a much more perminant fix and a lot stronger
picked up my welder for around ?150 and won't need to do the job again
a good site to learn from is mig-welding.co.uk spotted by a chap on here previously
go on.. you know it's the right way :wink:
k
and dont worry about welding, as part of my apprenticeship i had to do some welding , i can mig and stick weld but cant tig!! just aint got a welder, but cant really justify ?150 bar for one mod? although wud be handy as i do want the car totally smooth.
another Q? if you weld up the aerial hole on the wing, would it rust on the inside of the wing?as it cant be treated unless you take the whole wing off?
If you use weld-through anti rust primer before welding it all up I doubt you'll see rust again for years and years
as for the welder.. it's a 20 odd year old car, you'll need it again sooner or later :wink:
true
also tryin to find sum old skool bbs rims or sum ronal turbo's 2nd hand if possible, which is a total bastard of a job. just want the whole car smooth and lowered, no body mods, just smooth!! also u kno neone sellin a larger lump 1.6, 1.8? cheers j
if you check out the for sale section there's a couple going I think, although you'll need to move an engine mount to go from smaller block to large (if ya didn't know already)
Oh, and you'll get there… always takes longer than expected, thought mine would take 8 months max… in the end wasn't finished for 16 (and still isn't totally finished
true
hope it all goes smoothly, will you be spraying it yourself as well?
See - You'll need that welder again already! :wink:
My Build Thread
yer fair enuff
ill try n get sum pics up!!
how do i get pics up on here?
once you've signed up (free) and put the picture on there, you'll have a IMG link under it, copy this into a new post and your picture will be here
make sure the pics aren't huge though
yer
