Fitting Mk3 Recaros
(In Topic #146067)
Fitting Mk3 Recaros
Now I'm Ok with cutting and welding the bases to fit the mk1 runners but my question is: are the seats the same shape as mk2 recaros? They are going to be either retrimmed in cream leather or recoloured and I want to get some protective covers.
These are the covers on eBay for a mk2:
http://www.ebay.co.uk/itm/290564489572;jsessionid=EDF2BFA05F3D741F1C245B6B0652E239?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_nkw%3D290564489572%26_rdc%3D1
Will they fit?
foxy
I was told they are a bit wide for a Mk1.
Yes I fitted them and they are too wide. Basically cut off the out side leg and then weld it back on a bit further in.
There is a good guide on the caddy forum:
http://www.vwcaddy.com/showthread.php?2176
The guide is about fitting mk3 seats but the bases are the same anyway. It's what I used and fairly straight forward
Does the gear lever hit off the seat or anything?
Are they heated seats, if so are you going to wire them up?
Gear lever is fine and I did wire ip the heated elements aswell. Passenger seat works but drivers doesn't. Typical eh! I was lucky that my Rivage had the loom and controls already in place, I just had to change over the connectors underneath the seats.
