Driver Seat Reupholstery
(In Topic #72264)
Someone has very cleverly closed the slit on the left side and then moved the adjuster and lever onto the right side. This answers why both my front seats are in immaculate condition and not suffering from the usual bolster wear commonly found.
Does anyone or has anyone had just the black leather-like material reupholstered by anyone as this would make it a true driver seat??
Do I stand any chance??
Cheers,
'83 Helios Campaign Gti
The real problem is the base, but if you take apart the bases, you can use the upholstery and foam from a passenger seat on a drivers base.
Life Member
Have you done this before Rajan??
Life Member
After that I got Dave to stitch them back up for me a put in some new piping sections. Good job he did too!!
Check he has the vinyl or get another one from the correct seat.
Good luck
Rajan
Chairman
I dropped the seats off at his works and he did them in about 3 days. He had some upholstery very similar to the passenger side so the drivers was replaced. I saw numerous rolls of upholstery in his racks to cover the various styles so he should have something to suit most tastes!!
Most recommended.
