Door water shredder sheets
(In Topic #150419)
http://www.ebay.co.uk/itm/Vw-Golf-mk1-mk2-GTI-16v-8v-G60-Door-Card-Plastic-Sheets-Euro-Campaign-Caddy-/200878866983?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ec5504227
(not sure how to edit link title, sorry)
http://www.diy.com/nav/garden/garden-care-watering/growing/plant_care/-specificproducttype-plant_protection___support/B-and-Q-Polythene-Sheet-6m-x-2m-10278279?noCookies=false
Good old ebay, that seller must be laughing every time he sells them!
but thought an enthusiasts forum would be the first place i got laughed out of the door!
Cut it to size then added the extra flap to the sheet with the carpet tape.
stuck it to the door and then used a heat gun to tighten the plastic and stick the 2 shhets of plastic together so the water couldn't get between the main sheet and the flap over the vent.
I only have a picture of my 1st attempt and didn't have this extra flap over the vent which is why I highlighted it as I had water leaking in and had to re do it. It gives an idea of how I got it to look though……….
please could you elaborate on this 'doubled up' flap thingy that should be part of the plastic sheeting and the rubber flap you advise should be over the vent on the inside of the door.
on mine i have found that just above the vent, there is a thin strip of black plastic about 15cm long (one side is curiously furry for some unknown reason) and this clips in, via (about) 4 little pegs, which might secure a flap but I found no such flap - might this be there to secure the rubber flap you mention?
as regards the flap that is part of the plastic sheeting, can you clarify what do you mean by doubled up?…I see from your picture from your first attempt that there is a gap in your sheet where the vent is and i can easily see that if you had not cut out that gap the vent would/could be covered and even taped on, if you wished, by applying some tape to it and to the door just below the vent (although the tape would ultimately peep out from below the door trim) but, if you taped it up, it would certainly hamper the functioning if the vent so i'm pretty sure that's not what you mean.
maybe on the original plastic sheeting this 'gap' flap extends twice as much below the rest of the sheet so that you could fold it up on itself and then hang the bottom part over the inside of the vent so you end up with 2 flaps - one of each side of the vent but then why would you need this if there is the rubber flap I've imagined above?
ben
the '2 sheet' method has been around for a while, what you do is get a sheet cut to half the height of the door and stick it down the middle of the door and tuck it in all along the bottom of the door. this is done so any water that makes it past the glass gets directed straight into the bottom of the door rather than drippign down the inside of the main sheet.
the reason is to get a fully watertight vapour barrier with just 1 sheet is tricky, you have to get it stuck on just right and use a good quality waterproof glue (hence why peeling the oem barriers off is very difficult!!)
if you look close at the inner door skin you'll notice it kinks inwards, and along the bottom edge there are a series of holes, these are there so that any water that comes down the sheet gets caught and drains away. if you dont get the outer seal 100% perfect it'll sit in the bottom and eventually ruin whatever you use to stick the barriers down, unless you use very good adhesive.
the 2nd lower flap bypasses all this hassle
rubjonny said
aye the plastic strip you mention is what holds the rubber flap over the vents.
Sounds like a great idea but I'm struggling to picture that in my head. Does the second piece tuck down in behind the door vent? It would be good to see the finished article if anyone has a photo?
Here's what I've done so far to cut the shape -
what shape would the second piece look like? and stuck to where on the door:
- I know the top of the door has been butchered. that'll get fixed too
KP
The film is in red and the door frame is green.
Could I stick the second piece to the beam that holds the grab handle first? tuck it in behind and over the vent and then put the whole piece over the top??
and would the 2nd piece need to be secured at the sides??
I guess you could stick it to the "beam" that supports the pull handle. The important thing is that any water dripping off the bottom of the window is deflected away from the bottom of the door card.
Attach the second piece to the door as you want to and then poor water down the outside of the moving window you should see where the water drops in and where this second piece then does its job.
then stick the top sheet over the entire door, later vw use a foam sheet similar to what you lay under laminate floorign, this gives a little bit of sound deadening. only thing is I dont think there is any room behind the doorcard for this kind of thing so probably best to stick with plastic sheeting
i don't have the rubber flap on the inside. I'm guessing these are no longer available? And would it even be required anyway with the second internal sheet?
I suppose I could add a smaller piece of the sheet to the outside of the vents? But just not secure it at the bottom?
The Mk2 also has the flaps but they were fitted into a plastic housing that clipped in the boot right down by the chassis leg where the bumper irons bolt.
Back to the MK1 there are also pieces of thick, low density foam around the winder handle and the pull handle.
Fitting all of the above makes a big difference to how much unwanted noise and draughts can get into the cabin. Its worth doing properly.
