Door seal HELL!!!
(In Topic #93137)
Door seal HELL!!!
Sorry for the rant and to GPC but the rubbers just are not good.
Batman.
if anyone has any ideas or help that would be great, i will put some pick of the rubbbers up on here tomorrow.
i put the original seals back on after respraying and it was still MILES out, same issue i.e. the door would not just shut, but its basically a massive fiddle, most things on a mk1 are like lego, but the door seals make NO sense to me at all, y not just have one big seal within the door frame like a mk2 eh?
there are several different orders/ ways in which the seals can fit, theres a seam/flap on the longest one, that u have to prise in and tuck underneath it
basically keep trying until you get it mate, also moving the door pins themselves helps alot, not just the locks.
all im saying is keep ur gpc ones for now, and keep trying really, as i had enough trouble with original genuine ones, i spent a whole day fiddling about with them
good luck, hope that helps
JJ
79 GTI / 90 JETTA
Tian :dontknow:
crazyquiff said
Not the first time GPC have sold stuff as OEM only to be a pattern
Solution?
Tian
79 GTI / 90 JETTA
done this a few weeks ago
used the seals from GPC - you need three of them as there are only 4 door seals left.
You will need 1 complete seal and about a quarter of the spare one.
I fitted mine as per usual and had the problem of the door not wanting to shut and requiring massive pressure to even look anywhere near like closing.
the problem was the part of the seal running down by the hinges - it just need pushed further out towards the door skin and reglued - you can see if you close the door over and lok down the hinge line you will see where it is nipping the seal and not allowing the door to close….
now they close spot on….
GPC seals are fine.
