Door Hinge Replacement
(In Topic #76245)
I've got a cabriolet and there is play in the bottom hinges on both doors - I expect its probably a common problem. It looks as though the play is in the centre section of the hinge itself, which is the part that bolt to the car itself.
They look similar to a Mk2 hinge and I tried to get one from a scrap car, but could drive out the hinge pin even with the door removed, so gave up.
Has anyone any advice on repacing the door hinges?
The pins are a Gareth Hunt to takeout.
