Cellulose v 2 pack
(In Topic #96370)
Cellulose v 2 pack
but so far im happy with the cellulose finish even thou Im told never been as good as 2 pack
In my limited experience, cellulose needs to be thicker than 2-pack in the gun in order not to run, and even then is more prone to it, and is also more prone to orange peel.
2-pack was brilliant - thin, so easy coverage with no orange peel, goes off quickly, chips less easily when dry, shines better.
BUT, despite what you may hear, 2-pack is dangerous stuff. No filter mask on the market, even the best 3M ones, is approved for 2-pack, and you therefore need an air fed mask. I have a 3hp 14cfm compressor and it won't drive both a mask and the gun, which means you need quite a bit of equipment to do it safely. If you want to scare yourself into living a long life, spend an hour on the 'net doing your own research…
Oh, and you need to make sure everything is well covered and masked if using 2-pack, as the overspray doesn't dry before landing on your nice shiny car/bike/furniture etc like cellulose. It lands, sticks and then dries, leaving you with a problem…
Hope this helps…
What he said chaps lol
im goign to stick to cellulose and be happy its more than enought for my baby. Maybe in the future ill get a professional job done.
I'm not going to chance my health again so will go for the celli option. I might even use cans as it just for the boot area.
Treason!
