cabriolet windscreen and rear window..
(In Topic #77755)
It is relatively easy to replace the rear windscreen - to get it out you just push it out from the inside (although I guess you've probably extracted yours by now in pieces).
Once you have an edge or a corner out of the seal the rest should come out fairly easily.
I reckon this is probably best done on a warm day when the rubber seal is softer - although you could probably make it soft by pouring hot water onto it.
You could probably get a replacement window from a breakers - or I guess from autoglass.
To put the new window back in, you make sure the seal is clean - then lay a long piece of string in the slot that the window will fit, going twice round the inside of the seal.
Then you lay your new window on top of the seal, and pull the string from inside the seal slowly out along the edge of the window - which should (in theory) pop into the seal and stay there.
Hope this helps
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
were abouts are you???
cabrio windscreen
