Cabriolet carpet loose
(In Topic #133555)
These rot away over time.
Another issue is that if the top leaks and the water gets in it leaves the carpet smelly and the underlay holds the water, so some people remove the underlay, this leaves the carpet un supported, so when you stand on it it pulls away.
Make sure the top is okay and lift the carpets out and replace the underlay.
If you know someone with a binding machine or industrial machine you could sew on some new fabric.
Or you could use carpet glue to hold it in place.
1988 1.8 carb Golf Clipper
Cheers Chris
