Cabrio Springs
(In Topic #79142)
Cabrio Springs
I have a '91 Cabrio with a saggy back end, I suspect the local VW dealer supplied tintop rear springs rather than genuine cabrio springs. Where can I buy genuine rear springs from someone who knows what they areselling. I do not want to lower the car as it runs on 15" 185 BBS RA's and clearance is tight.
Thanks for any advice.
Tim
So many dubs so little time, so much rust
BTW, the car has just had a set of Golf2 15 195 BBS RA's bought for it, I wonder if they will fit?
DubPartz
a) You have a body kit (mine is late '91 with full kit)
b) Saggy back end
c) Lowered
d) 15 195 RA's
I suffer from three out of four of the problems but I waiting for the new VAG springs to be fitted. In the meantime, I am fitting some 14 195 Passat alloys which at ?40 for five cost about half the value of one BBS RA.
Anybody want a full set of some nice BBS RZ's?
TimHale said
Maybe, it is a problem if:
b) Saggy back end
c) Lowered
d) 15 195 RA's
a) It's been fitted with a clipper kit and that's whats currently being worn away by the tyres but it must only come inwards from the metal arch by 1-2mm.
b) It does sag a bit
c)Standard ride
d) Were these fitted on Sportlines though ??
DubPartz
I've just fitted the Cab with my BBS RA's (thanks Ebay) - no clearance issues despite the fact that I have not fitted the new VAG springs. The wheel data is ET35 15H2 7J whilst the old wheels are BBS RZ's ET33 14H2 6J
The visual effect is stunning and not a great deal of money, in fact less than a set of the cheapest wheels (no rubber) from Halfords.
Why didn't I do this before?
I only get wheel rubbing if I have real heavy ppl in the back, even then it is only when i hit a bump or something
I've taken my BBS's off and parted with the car.
If you saw any earlier threads you'll see a swap deal was in the offiing for a 4x4. Well the deal went through.
Now I can pour all my enthusiasm into my tin-top
DubPartz
