Cabrio hood fitting.
(In Topic #72136)
Drew well done and thanks for all your hard work in setting up what will i hope become the best owners club ever. with your members list you can't fail.
A mk1 Cabrio is a real golf.
My real car's a 4x4.
Its about 7 pages long! Can email it to you if you like. Just PM me.
Cheers,
Ross
Life Member
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
I've emailed it to you so you can do some editing more easily.
Cheers,
Ross
You have email and a PM!
Good luck with it,
Ross
The saga
Would be very interested in seeing the document once iot's on here, even though we don't need it, it's all very useful info.
The rear window leaked when I got the car and I took the rear window and realised how rusty the frame was. Its lost its rigidity and creates a big gap at the bottom between window and frame. I cleaned the seal up and refitted it then sealed it all up with silicone sealant. It stopped the leak and hasn't started again yet, its been 2 years! The roof should stay intact enough till next summer hopefully!
Prowler, do you know if they used any sealant on your rear window when it was fitted or does it seal enough anyway? When I took mine apart there was some white sealant that looked original but had gone hard and cracked/disintegrated.
The only sealant used on the new ones was a thin film of black silicone sealant inside the seal/frame joint, as shown:
The Clipper did require a bit at the bottom of the window itself, but both are bone dry now.
