cabi roof
(In Topic #117356)
cabi roof
There a little gaps where the seals are split for the roof to come down.
Has anyone got any suggestions to hepl me cause everytime i wash the car the inside get's wet
Chairman
Are you referring to the rubber seals underneath the actual hood? If so, I think you'd be better going for a new set or good secondhand ones.
If it's your hood creases that are leaking then there is little option than to get a new hood. Once the outer skin has been cracked, water will leak in. Cracking can be caused in cold weather in the vinyl hoods so I never put mine down unless it been warmed up in the sun first.
If you need a new hood and are close enough to Northern Car Hoods, below left <<<< then you can get a 10% discount if you're a full member!
Dan
