brake pipe fittings size ??
(In Topic #78326)
can anyone confirm the size of the brake pipe fittings needed to make your own brake lines. i know the size of the pipe diameter just need the fittings sizes
cheers for any help
Use one of the old ones to check the thread against :dontknow:
DOh
cheers anyway
Mike.
1983 White cabriolet GTi
PM me if interested.
Mike.
Cheers for that though appreciate it
It's not thje connectors you'll mess up, it's the pipe. I could not get the correct flare at the end of the pipe dispite many hours of trying. I brought a job lot of the unions, think there's about 100 or so in there, and 25 metres of copper pipe, but I think I've wasted well over 10 metres trying to perfect the technique which I never managed. It's therefore only taking up space in my shed, so if it can be of use, don't hesitate to ask as I' rather it went to somewhere useful than got chucked!
Let me know if you're sucessful making the pipes up, I'd be interested to know!
Mike.
cut pipe with small pipe cutter. debur with small knife. fit into clamp 3mm above seat (hint the press plate back is the right thickness so use it as a guide) look furthest clamp from pipe first then closest. fit press plate (the little top hat). fit press. wind in. job done. it really is that simple.
