brake pipe fittings size ??
(In Topic #78326)
hi
can anyone confirm the size of the brake pipe fittings needed to make your own brake lines. i know the size of the pipe diameter just need the fittings sizes
cheers for any help
cheers for any help
When I was doing mine there seemed to be only 2 types, metric or imperial. You need the metric ones. From memory a 10 or 11mm spanner fits or you can get a special brake spanner like a ring key with a bit cut out.
Use one of the old ones to check the thread against :dontknow:
cheers for the reply mate, would check against the old but the cab i bought was an abandoned project and he had cut off the old pipes connectors from the master cylinder so ive only got the pipework
DOh
DOh
its ok sorted. found one in a box of bits that was with the car. 11mm
cheers anyway
cheers anyway
Having done the brake pipes on my car, I would throughly recommend using a proper brake spanner. It's so easy to round the nuts off with a normal spanner, as I found out!! They only cos a few ?'s and are well worth it!!
Mike.
Mike.
1983 White cabriolet GTi
cheers for the tip mate
I've got a box of the correct sized unions, and about 10 metres or more of copper brake pipe you can have if you want it?? I brought it to make the pipes for mine, but as I said in a previous post somewhere, I could never get the ends of the pipe to form properly, so i gave up and brought a ready made set in the end! They are yours for the cost of the postage if you want them??
PM me if interested.
Mike.
Mike.
cheers mate but ive ordered some bits BUT i might PM you for em when i balls up the small number of connectors ive got :-)
Cheers for that though appreciate it
no problem.
It's not thje connectors you'll mess up, it's the pipe. I could not get the correct flare at the end of the pipe dispite many hours of trying. I brought a job lot of the unions, think there's about 100 or so in there, and 25 metres of copper pipe, but I think I've wasted well over 10 metres trying to perfect the technique which I never managed. It's therefore only taking up space in my shed, so if it can be of use, don't hesitate to ask as I' rather it went to somewhere useful than got chucked!
Let me know if you're sucessful making the pipes up, I'd be interested to know!
Mike.
Mike.
will do mike :-) bugga dreading it now, like i said be prepared for me askin for em 8O
Yes, eleven millimeter is the normal and standard size of its pipe fitting. You just need to choose better pipe and durable. There are some pipes that are easy to torn.
with the right tools the flare is easy. it's only a single flare. get the tool from machine mart. rad the instructions. read them again.
cut pipe with small pipe cutter. debur with small knife. fit into clamp 3mm above seat (hint the press plate back is the right thickness so use it as a guide) look furthest clamp from pipe first then closest. fit press plate (the little top hat). fit press. wind in. job done. it really is that simple.
I'm in process of redoing my brakes lines. And have no idea of brake line size or nuts I need. I see folks say it's 11mm but that's the wrench size right? So is that M11 x 1.25 nuts? How do I determine what is already on the car?
