allign doors
(In Topic #100178)
allign doors
Hi how do allign the doors.
thanks
thanks
Life Member
Re: allign doors
thanks
My doors have dropped I'm gonna have to do the hinges I think because I undid the lug situated inside the door frame lifted it up then tightened again…
I almost got my door wedged in place cause of that though!
Depends how much down they are I'm guessing, been meaning to ask for a while also!
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Got this link for you guy's. Still got to do mine, but I have bought some striker pins that the door catches shut onto. Undid mine but the capture nut they bolt into moves around (obviously so you can adjust the shut). Does any one know if i undo them fully the fixing will drop into the body work and be lost.
Let me know if this works guy's.
http://toplessrabbit.com/forums/viewtopic.php?f=8&t=1476
wont drop into the body work.
1988 1.8 carb Golf Clipper
Cheers,
will crack on and sort them.
Life Member
what about if your doors are about 1/2" off..? lol
Follow us on:
Follow us on:
Little golf had the same problem. He phoned the main dealer and there advice was to bend the hinges into place. He posted this works well.
Any way put the door striker pins in, but still got to adjust my door.
Mind you mine isn't 1/2" out. Went to get my angle grinder out to notch a couple of washers out but my Bro has been at my tools again there's nothing left on the disc Grrrrrrrrrr
