Why does the oil pressure drops down?
(In Topic #96559)
Sorry if I?m not using the right section of the forum, but I really need your help (I also read that a technical section is about to be created. Great!)
There it goes: when I put the engine to work the oil pressure seems to be ok, around 5 to 6bar (the car has an oil pressure gauge at the central console).
However, after a few minutes after putting it to work ? and this can vary between 15 to 30 minutes depending on ambient temperature ? the oil pressure drops down and the red light starts flashing whilst the gauge pointer rests to the left side, quite below 1bar!
I don?t drive the car in this condition and lately I avoided taking it out of the garage. But the summertime is coming!
I read some related topics in the forum but all of them seem to report electrical, dashboard and/or pressure sender problems. This seems to be different as the oil pressure is ok at the beginning and drops down as the engine heats. Apparently it has to do with the oil getting thinner with engine temperature but I don?t understand why and this is driving me crazy. The best reply I can get from the mechanic is that ?we must open the engine and see . . .? which is not very comfortable at all!
Any idea?
I'm running a DX series 1.8 cabriolet with the Bosch K-series fuel injection - original non-rebuilt engine with 114,000 miles on the clock.
Oil - Shell Helix-plus 10w-40
Oil pressure (warm engine) at idle is 2 bar / 1500 RPM 4 bar / 2000 RPM 5 bar - is about 1/2 bar when engine is running hot.
Try flushing with flushing oil and refilling with Shell Helix-plus 10w-40 to see if you get an improvement would be my first step.
M
Re: Why does the oil pressure drops down?
rpvmoura said
I have a problem with the 1.8i engine of my karmann cabrio.
I read some related topics in the forum but all of them seem to report electrical, dashboard and/or pressure sender problems. This seems to be different as the oil pressure is ok at the beginning and drops down as the engine heats. Apparently it has to do with the oil getting thinner with engine temperature but I don?t understand why and this is driving me crazy. The best reply I can get from the mechanic is that ?we must open the engine and see . . .? which is not very comfortable at all!![]()
Any idea?
Really need to know engine mileage etc but sounds like worn shells,is there any noise from the engine at all?
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
Michael said
Don't know if this helps:
M
Thanks Michael,
I use a synthetic Mobil 10W40 oil (don?t remember the name) and I?ve been told that I should use a mineral one. What do you think? Is the Helix Plus a mineral or a synthetic one?
I will check the oil pressure against your figures as soon as I get home in the evening. But I?m sure that at idle and after engine is hot (cooling fan on) the oil pressure is as low as yours, i.e., less than 1bar!? Is this ok? Thus, why does the red light flashes?
Pedro
83 BBS MK1 GTI 69 T2 PANEL VAN i am back let the trouble begin
collo16v said
Hi and thanks,
I'm pleased to give you all the information you need! Please ask me![]()
The engine have less than 80.000km and the engine sounds like music. It starts like a clock even after long periods off, it doesn't lose any oil and the colour of it is alloways clean amber (not burnt black). It seems that as the oil gets thinner it escapes through any "damn small stupid hole" to elsewhere inside the engine I can't figure out. Can it be any oil pump damage or malfunction due to the long periods the car is off running?
Pedro
"Oil pressure (warm engine) at idle is 2 bar / 1500 RPM 4 bar / 2000 RPM 5 bar - is about 1/2 bar when engine is running hot"
should read "is about 1/2 bar lower when engine is running hot"
Michael said
sorry matie typo
Ok! And about the oil, do you use a synthetic or a mineral one? What is you experiece?
Pedro
Your Mobil oil is equivalent - good oil
who votes for:
- worn shells
- pressure sender(s)
- oil pump is damageg
- unapropriate oil and/or brand
Please don't make me agree with the mechanic and let him open the engine without having the diagnostic.
Happy Easter!
When cold 5 bar, when warm (but not hot) 4.5 bar when driving and 2.5 bar at idle, when thraping it long distance down the motorway 3.5 - 4.0 bar and if I then go to idle the pressure drops to 1 bar….it's been like that for 3 years and no rattling from the engine at all. All those pressure readings were with the oil sold by VW (forgot the name of it)
I put a cheap oil in early last year, just to give the engine a flush before a proper service and went to Santa Pod in it, the oil pressure was 5 bar cold, but when she got hot it didn't even manage 2.5 bar when motorway driving 8O ……so try changing the oil for a good brand, before you take the engine in for open heart surgery.
with only 80 clicks on the clock, running like a watch and burning nice and clean I'd be loath to pull it apart.
M
Thank you Cero, GAMMIGOLFGTI, Michael, Bert and Jay666.
Now I've got good advise and enough stuff to help me finding out what is realy happening (before opening the engine).
Besides, I fell less concerned as my engine beaves much like GAMMIGOLFGTI's one!
I'll start to buy a mineral oil from a local VW dealer, change the oil filter and see what happens. Then I will change the pressure senders and I will try to chek pressure directly from tha block with a gauge.
I will let you know the results
Thanks again.
Pedro
i'd be surprised if the oil is the problem. worth a try though. best bet, is to follow berts advise, to be sure.
