which gearbox/clutch????
(In Topic #128264)
THANKS
You can use any 020 gearbox but must match the clutch FRICTION DISC to the (input shaft of) the gearbox. I've never counted splines but most 020 boxes have a 22mm input shaft, 16V Mk2 and some later Mk3 boxes have 24mm input shaft.
There's the gear ratio guide on the left but you're better off relying on the fastgolf one because its been kept updated, there's a few little errors in the one on the left.
and its fantastic for acceleration.
mk2 16v box has longer gears so im told. depends on what you want from it.
i prefer acceleration!
as said above so may different ratios on the 020 box's always check codes first
drop us a pm if you want a 16 valve box!
Saab 93 diesel daily
paul_c said
16V box has a longer 2nd gear, but the rest of its ratios are the same as a 1.8GTI Mk1 box.
do you know why? think my box is the original one but was on a 1.6 engine. no idea on code but do you think they would be the same( 1.6 & 1.8 )
might keep that box now!
How does the 9a compare to the kr 2y box?
Gear Up!
