what should myoil pressure be?!
(In Topic #102944)
i have done my research and think it sthe sender at fault, but…. im at work the engine has just been put in i want to double check it!! i have an oil pressure tester in my hand can someone tell me what i shopuld be expecting it to read? at cold idle, hot idle, etc
i'm probably panacking over nothing, just dying to take on its first test drive!! but dont want to if oil pump broked!!
pls help se my mind at rest!!
its a 89 kr 1.8 16v
its a 89 kr 1.8 16v
Should be 2 Bar @ 2500 rpm with oil temp @ 80 degrees.
thank you very much, its all good but still probs,
check this, as its linked
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=48346
