weird idle
(In Topic #125524)
weird idle
Its fine one day then not the next.
My engine is the 1.8 8v DX
Ive herd that the switch under the throttle body can cause this
Ami
Fuel pressures
Cold start valve-cold=ok
Cold start valve-hot=ok
Checked compression
Checked Aux Air Valve
Checked fuel pump flow
CO mixture adjusted to 2.2 @ 950rpm
Checked injectors
Checked timing=ok
Airleak check=ok
I think mines now got to be the distributor after all these checks, getting one refurbed by CrazyQuiffs.
Also worth reading, the 'Fuel Injection' under -Technical link in left margin<<<
Good Luck, hope this helps.
8V
16V
Sportline
Campaign
16V
Sportline
Campaign
