Water-Oil Cooler removal
(In Topic #113190)
I am hoping that there is nothing more serious inside the engine, and that it is the Oil-to-water cooler that has given up the ghost. Is there a way of checking if it is this? Can it be bypassed or anything?
Also, I might be being incredibly thick (at a wedding last night - bit hungover!), but how do you remove the cooler unit?
Cheers for any help…….
to clean the gunk out, drain the system and flush with hosepipe as best you can, then refill with plain water and put in a cup full of bio washing powder. run engine till hot, allow to coolthen drain and flush again. repeat till oil gone
refill it with plain water at first, since its nice n warm out no need to worry about it freezing and if you only run it for a week or so to proove if its cooler or not shouldnt have any issues with corrosion.
