Flange between gearbox and engine
(In Topic #239338)
Metal flange
Loose isn't a bad thing, as if you have a oil leak on the rear main, then it will run out more easily, and yes you could take it off.
Briano1234 said
That is to keep road trash out of the clutch.
Early-1800 said
Is there enough left to drill a small hole and fit a small nut and bolt to hold it and stop it rattling and falling off?
That was what I was thinking off doing if it needed to go back on. I'd have to drill both though as there seems to be no thread on the other one
You could also try a self drilling sheet metal screw.
I once had to drill through a Water pump housing on my 81 diesel, where the t-stat cover stripped. I nutted it on top and I think about 200Kmiles later when I sold it was still that way.
Personally I'd not do away with the plate, without it there's a large enough gap left to allow dust / dirt / water in… it's there for a reason.
